100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> Timber panelling 3'-0" high within room Revit 2010
Hi, I have created a village hall with ancillary rooms. Within the main hall I wish to include timber panelling about 3'-0" up from floor level and then topped by a dado rail of some sort. What is the best way to achieve this. Thanks in advance to all. reagrds Mark
There are two main methods to do this. The first is to create as a layer in the wall properties and unlock the layer and stretch it down to the correct height in a section. You could use a wall sweep to create the rail. The second, which I prefer, is to create a seperate wall for the panel with a sweep for the rail and then align and join it to the main wall.
I use the added wall method for something like this. I believe the first method will cause you problems because I have seen the exterior wall finish applied to the secondary layer in some cases. I don't know if that is true all the time but the thin wall works so well I don't need to do the other.
Thanks. I have made a new wall 40mm thick and called it panelling. Then in ground floor plan, I placed the panelling up against the existing wall. then I used the Join tool. Thanks
Room Tag With Ceiling Offset from level, or Ceiling High |
Sun, Mar 8, 2009 at 11:03:00 PM
Timber Shell Structure |
Fri, Nov 30, 2012 at 3:39:18 AM
How would I go about creating a timber frame? |
Fri, Feb 10, 2006 at 3:49:50 PM
Timber Framing |
Tue, May 9, 2006 at 9:04:39 AM
Some questions. |
Mon, Mar 27, 2006 at 8:46:10 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
