84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Importing one rvt file to another (spiral stairs from this site) (2010)
17 Posts No Rating |
I am a student and a fairly new revit user, so I apologize if my question is obvious to a more experienced user. I downloaded the spiral staircase from this site (http://revitcity.com/downloads.php?action=view&object_id=7155) thinking it was a parametric family, but it turned out to be a rvt file. When I tried to simply copy and paste it into my project, it got all wonky... specifically, the railings for the stairs turned into a solid ring at the floor level. My question is, is there a better way to import the file into my project than just ctrl+c ctrl+v?
That is a fine way to import. It sounds like you just need to rehost the rail to the stair.
If any part of the stair, such as the rail or material, has a name that is already defined in the project then the project settings will overide. Give the rail a unique name before importing.
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
STAIRS IN LINKED FILE WON'T SHOW UP IN MAIN CENTRAL FILE 3D |
Mon, Jun 25, 2012 at 3:58:52 PM
Spiral Stairs |
Fri, Jul 4, 2008 at 1:34:57 AM
Residential Spiral Stair |
Mon, Feb 16, 2015 at 10:02:06 AM
Spiral Stairs |
Sun, May 27, 2007 at 8:06:07 AM
Members: | 2022280 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
