Forums >> Revit Structure >> Technical Support >> quantity of colums
39 Posts No Rating |
Help me, please/ Can I count quantity of architectural colums by specification?
You will get much better results by using 'structural' columns.
Thanks, I know but I have to insert exactly architectural colums.
lanskaja, I don't believe you understand. "Architectural" columns are kind of mis-named. They really act like pilasters and will assume the material of any wall they engage.. Structural columns can be concrete, steel or even other materials like brick. In addition, you can have unique column families like doric or ionic...etc. Any of these columns will schedule and count.
I see. I think any object in Revit I can count by schedule. but I found out I can't count architectural colums, balusters....
For a quick turn around a small tip: Slect the Arch. column and click on Edit Family. From the Categories and Parameters select Structural columns and reload. Generate schedules for Structural columns, after getting results you can undo till load family.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
I know select the column and click on select all instances is also much easier and faster option...but the above solution is for proper format.
Pavan Reddy
Revit Manager
Thank you
Is Revit able to do serious quantity surveying stuffs? |
Thu, Jan 20, 2005 at 12:03:34 AM
Revit 2009 - Quantity Take offs |
Thu, Sep 9, 2010 at 4:41:23 PM
quantity of balusters |
Tue, Nov 10, 2009 at 7:34:46 AM
i need to show colums, bearing walls and primary structural grids in my revit.. |
Mon, Mar 31, 2014 at 7:57:10 AM
rebar reinforcement quantity take off |
Mon, Apr 5, 2010 at 4:55:26 PM
Members: | 2115765 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
