40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevation Tags in Section views?
Tue, Nov 17, 2009 at 8:29:19 PM | Elevation Tags in Section views?
Snodaisy
Can this be done?
Wed, Nov 18, 2009 at 7:16:40 AM | Elevation Tags in Section views?
You could do a detail callout bubble and use the reference other view to pick your elevation.
Wed, Nov 18, 2009 at 1:57:24 PM | Elevation Tags in Section views?
Snodaisy
Thanks for the input. This has lead to trying to create an elevation tag family with the ability to rotate the arrow in the direction of the elevation. Do not know how to set-up reference planes so an angular parameter can rotate the arrow around. It seems my center point is always off. Any input appreciated.
I've attached the files for reference.
Wed, Nov 18, 2009 at 3:38:27 PM | Elevation Tags in Section views?
Snodaisy
Victory. Got this by creating four arrow with a visible parameter. North, South, East, West. Easy Peazy - no need for radial parameters.
elevation tags!!!!!!!!!!!!!!!!!!!!
Fri, Apr 24, 2009 at 5:44:24 PM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:06 PM
TEXTS in Section and Elevation TAGS
Mon, Jul 30, 2012 at 8:46:14 AM
over-riding elevation tags
Wed, Oct 1, 2008 at 3:37:16 PM
Room tags in section views
Tue, Sep 27, 2005 at 4:39:15 PM
Page generation time: 2.5101
