64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Upper component showing up in floor plan
Tue, Nov 17, 2009 at 4:22:21 PM | Upper component showing up in floor plan
jennijenj3
I'm having multiple issues in revit.  I'm using an office template for the first time created by a co-worker so i'm wondering if something went wrong with the set up.  I'm working in Architecture 2009.
The biggest problem I'm currently have is viewing upper casework in the floor plan.  I have the cut plane of the view range set at 3'6".  I have my upper casework (generically created from create in place component) at 4' start - 6' end, and it's showing up in the floor plan.  When I go to edit the compant (that is showing up in the floor plan) an area of the screen shows up light gray and no pink (draw) lines appear and I have to quit family edit.  If I change the view range cut plane to 7' then I can see the pink lines and edit with out any problem, but I still get a lighter gray area.
I'll attach a few print screans.  The first one shows my view range set up.  The second shows what happends when I try and edit the upper component (note the light grey area).  The third shows the element props of the create in place componant.
Please help.
Wed, Nov 18, 2009 at 3:17:48 PM | Upper component showing up in floor plan
Anna2010
The only setting i see that is different is that I have my cut plan offset at 4'
Plan region not cutting component
Mon, May 7, 2012 at 10:04:56 AM
Upper Slab Profile Plan - RAC2009
Fri, Dec 5, 2008 at 5:10:29 AM
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Showing voids in plan
Tue, Nov 13, 2007 at 12:39:10 PM
Page generation time: 0.8013
