30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Line Styles with Text
Tue, Nov 17, 2009 at 3:19:51 PM | Line Styles with Text
AmyCRErde
How can I create a new Line Style that Contains text?  I am trying to create lines to indicate locations of utility lines so I'm trying to a "SS" within the dashes to indicate "Sanitary Sewer"
Tue, Nov 17, 2009 at 3:36:43 PM | Line Styles with Text
TKennedy
4 Stars: 7 Votes
As far as I know, you can't. You can have various lengths of dashes/dots, but no text. I would look into creating a repeating detail for what you want to do.
Tue, Nov 17, 2009 at 3:44:38 PM | Line Styles with Text
AmyCRErde
I can only assume that this is something that is overcome within the Civil Engineering version of Revit.
Tue, Nov 17, 2009 at 6:04:32 PM | Line Styles with Text
jarosa
jarosa Avatar
4 Stars: 5 Votes
No true linetype. What you can do is create a line based detail component...or use this one.
http://revitcity.com/downloads.php?action=view&object_id=6725
You can change the way the array works in the family, add parameters, etc.
Thu, Nov 19, 2009 at 10:15:17 AM | Line Styles with Text
MARS1276
1 Stars: 1 Votes
here, use this...  With this you can change the spacing of the text AND duplicate it to make a new linestyle type and edit the text to say what you want it to.  I developed it for our office and we have found it really great to use and really nice when we want all of the lines to appear spaced equally... or, in some cases, if we want to space the text so that it does not cover and hide a topo elevation number.
Hope this helps!
Thu, Nov 19, 2009 at 10:16:17 AM | Line Styles with Text
MARS1276
1 Stars: 1 Votes
Also, please let me know if this works for you; and, if so, let me know what you think.
Thu, Nov 19, 2009 at 11:52:52 AM | Line Styles with Text
AmyCRErde
I'll give it a try.  Thanks
Removing Line Styles
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles
Tue, Aug 5, 2014 at 2:57:29 PM
Removing Text Styles
Mon, Sep 19, 2011 at 12:17:03 PM
Deleting an Inherited Text Type
Fri, Nov 4, 2005 at 8:05:05 PM
Page generation time: 1.1287
