63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> editing dimension text
7 Posts No Rating |
Is there a way to edit the text after a dimension is placed?
You can add suffix/prefix but cannot edit the dimension. Best way is to get around this if required is to place text with opaque background over the dimension. We only do this for things like "see schedule" for door elevations and such. Other than that on the building model itself it is best to make it so the dimension reported is what it needs to be by making the building model correct.
HTH
Tom
32 Posts No Rating |
Tom,
I don't like the size and choice of text that comes automatically in the titleblock when I make a new sheet up. Is this customisable?
Audrie
you can edit and create new styles to your hearts content. Of course your limited to the TTF installed on your computer...
Removing/editing single dimension in dimension string |
Wed, Aug 26, 2009 at 7:12:02 AM
editing dimension text |
Wed, Jun 7, 2006 at 9:33:16 AM
Dimension Text [ 1 2 ] |
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text |
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension |
Tue, May 10, 2011 at 9:32:42 AM
Members: | 2017161 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
