Forums >> Revit Building >> Tips & Tricks >> How do I NOT print hidden objects?
11 Posts No Rating |
I have a suburb plan, site plan and floor plan overlayed.
I don't want to see the floor plan on the suburb plan, and I don't want to see the suburb text on the floor plan.
I also don't want to see the section and elevation tags on the ceiling plan, but if I delete them from one view, they will delete from all.
PLEASE HELP!
Use View->Visibility/Graphics, or shortcut VG. This is view specific.
Invaluable info, thanks.
You can also select the element and type VH. This will hide all elements within this family category... Basically just a shortcut to the Visibilty/Graphics menu without having to go into it.
In the view, right click on the mouse and go to "View Properties".
Click "Edit" on the "Visibility" menu and you can control the visibility of section and elevation tags.
Click "Edit" on the "View Range" to control other things.
Hidden Objects in Sheet views |
Fri, Jun 13, 2008 at 12:10:26 PM
Hide/isolate in view versus in print |
Sun, Mar 22, 2009 at 4:01:20 PM
MAKING HIDDEN OBJECTS NOT SHOW UP WHEN YOU PRINT. |
Fri, Feb 6, 2004 at 7:13:30 AM
How to really NOT print a hidden object? |
Tue, Mar 20, 2007 at 11:30:05 AM
Show Hidden Lines - Structural Foundations |
Thu, Jan 13, 2011 at 10:37:01 AM
Members: | 2118802 | Objects: | 23205 | Forum Posts: | 152309 | Job Listings: | 3 |
