42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curved/straight Ramp
Sun, Nov 15, 2009 at 3:47:39 PM | Curved/straight Ramp
prawfishy
can revit make ramp that is half curved and half straight?
it seems to only let the "run" part do either a complete circle or straight.
i tried drawing two then connecting it, but the second part would not raise, its just flat.
please help.
thanks.
Sun, Nov 15, 2009 at 4:25:43 PM | Curved/straight Ramp
prawfishy
nvm, got it. :]
Thu, Dec 3, 2009 at 2:19:15 PM | Curved/straight Ramp
dfitzladdy
5 Stars: 3 Votes
prawfishy, how did you do it. i'm trying to exactly what you did - a ramp that has both curved sections and straight.
let me know please! thanks!!
Fri, Dec 4, 2009 at 7:20:07 AM | Curved/straight Ramp
dfitzladdy
5 Stars: 3 Votes
nevermind i figured it out.
for those of you who are trying to figure this out too, it helps to use detail lines to set up a guide for your ramp.  If you're wanting to make a curved ramp, make sure to draw a line or two that points to the center point of the arch.  Using these lines as guidework, you can switch between curved ramps and straight ramps wheil modeling the same ramp - in other words they don't have to be separate.
Sat, Oct 12, 2013 at 10:24:47 AM | Curved/straight Ramp
ArchStudentWIT
3 Stars: 2 Votes
Try this link out:
http://www.youtube.com/watch?v=5GaIarzxYPQ&feature=youtu.be
Spiral wall along ramp
Fri, Jul 11, 2008 at 2:42:59 PM
Sloped curved ramp...
Sat, Oct 12, 2013 at 8:42:30 PM
12
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
curved curtain wall, straight transoms, curved panels
Tue, May 12, 2015 at 8:36:03 PM
Structural Curved Ramp with Walls
Wed, Apr 29, 2009 at 12:13:41 AM
Page generation time: 0.4012
