23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adding trim to a door
Sat, Nov 14, 2009 at 5:28:18 PM | Adding trim to a door
frankricharz
I have a sectional garage door that I need to add some trim to on the exterior.  What is the best  way  to  do it?
Sun, Nov 15, 2009 at 8:38:35 AM | Adding trim to a door
4 Stars: 201 Votes
My advice is: open that Garage door family and create the "Trim" you need then save and load into project, IF you don't want that you can create that by "create in-place" in the category door.... BUT i use the first option...
Sun, Nov 15, 2009 at 8:49:29 AM | Adding trim to a door
frankricharz
Thanks for the advice.  Now for the even more stupid question.  How would I create the trim?   Its nothing more than a 6" wide X 1" deep trim around the outside of the door opening?
Sun, Nov 15, 2009 at 8:53:45 AM | Adding trim to a door
4 Stars: 201 Votes
When you open that family you have the "Solid Sweep", create the path around the door then finish the path and create the profile with the shape you want, don't forget to add the "Material" parameter so in this way you can change the material in the project....
Wall Finishes Aligned to Door Trim
Thu, Jan 21, 2016 at 4:08:48 PM
Door Trim Parameters
Fri, Sep 11, 2009 at 12:52:57 AM
Edit/Add trim to Door Family
Thu, Jan 14, 2016 at 10:02:29 AM
door trim stops short of floor
Wed, Jul 24, 2013 at 3:24:32 PM
Specialty Door(s) - Help Needed! - Transom, Trim, etc.
Mon, Jun 4, 2012 at 4:44:07 PM
Page generation time: 0.4446
