112 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> gbxml export for Trane Trace
Fri, Nov 13, 2009 at 3:25:45 PM | gbxml export for Trane Trace
vinnygolfer
4.5 Stars: 4 Votes
hi everyone, has anyone tried to export the gbxml files and use them in Trane Trace. i tried it for the first time today, using Revit MEP 2010. i had some great outputs and some that need to be improved for us to use it more effectively. is there a good tutorial for this, or just some hints to get me going in the right direction. i set up the building information for the construction types, like roof material and windows. however Trane Trace didn't get that info. it placed in default info. and the item that i didn't put in, like the electrical loads for the spaces, and the lighting loads for them, Trace gave them numbers.
any help would be appreciated.
thank you
Try to learn at least one new thing every day
Tue, Jul 26, 2011 at 7:14:56 AM | gbxml export for Trane Trace
ruileitecastro
Hello,
May you help me in how to import to trace by gbxml outdoor air ventilation?
I share with you if you like to see the scheulle i am preparing.
I want this to calculate automaticly the ventilation and then export to trace.
By now there is no good resuslts.
Can you take a look?
I am very interested in develop gbxml between trace and revit too. And i am just starting.
Be able to just ask!!
thanks rui
REVIT TO TRANE TRACE
Thu, Mar 14, 2013 at 8:27:16 AM
How to include links in a GBXML export
Thu, Sep 25, 2008 at 9:35:01 AM
hosted famlies in linked files?
Wed, May 9, 2007 at 4:09:35 PM
Clerestory wall direction is reversed180 degrees in gbXML
Wed, May 19, 2010 at 12:49:18 PM
export to gbxml
Thu, Aug 30, 2012 at 9:48:38 AM
Page generation time: 1.3866
