39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> LINKED COLUMN GRID BUBBLE OFFSET
Thu, Nov 12, 2009 at 7:27:35 AM | LINKED COLUMN GRID BUBBLE OFFSET
adeuley
I WAS WONDERING IF THERE IS A WAY TO CONTROL THE DISTANCE OF COLUMN GRID BUBBLES OFFSET FROM THE CROP WINDOW. I HAVE THE ANNOTATION CROP AS CLOSE TO THE THE CROP WINDOW AND THE GRID BUBBLES ARE STILL THE SAME DISTANCE AWAY. I WOULD LIKE TO MAKE THEM CLOSER TO THE CROP WINDOW SO I CAN FIT IT ONTO A SHEET.  THE COLUMN GRIDS ARE IN A LINKED FILE.
Thu, Nov 12, 2009 at 9:02:46 AM | LINKED COLUMN GRID BUBBLE OFFSET
TKennedy
4 Stars: 7 Votes
You can't control the grids in a linked model, other than turning them on or off. What you can do is use the Copy/Monitor tools to add a set of grids in your model that you have full control over.
Thu, Nov 12, 2009 at 9:57:12 AM | LINKED COLUMN GRID BUBBLE OFFSET
adeuley
IT SEEMS KINDA DUMB NOT TO BE ABLE TO CONTROL HOW FAR THE GRID BUBBLES OFFSET FROM THE CROP WINDOW. I GUESS I'LL HAVE TO HAD IT TO THE WISHLIST
Thu, Mar 25, 2010 at 12:48:24 PM | LINKED COLUMN GRID BUBBLE OFFSET
MikeSoucy
Has this issue been resolved? I'm having the same problem.
Thu, Mar 25, 2010 at 2:05:40 PM | LINKED COLUMN GRID BUBBLE OFFSET
Turn off the linked file grids... one or the other of you should own the grids and the other ones copy / monitor them.  Then either way, you can adjust them in your project ... and turn off the linked file grids...
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:07 AM
Grid Bubble formatting between projects
Sun, Oct 26, 2014 at 8:33:05 AM
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:08 PM
Column Grid Text
Tue, Dec 11, 2007 at 9:33:37 AM
Different Grid Bubble for different scale views?
Thu, Dec 12, 2013 at 5:42:14 AM
Page generation time: 0.4692
