48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> dwg imort problem: arrowheads missing, text jumbled
Wed, Nov 11, 2009 at 3:15:11 PM | dwg imort problem: arrowheads missing, text jumbled
ldonkle
Hello,
We are new to Revit and are having trouble linking or importing our DWG details into Revit.  Linework is correct, but arrowheads are missing and text is becoming jumbled.  Please see attached files for reference.  Thanks in advance.
Tue, Nov 17, 2009 at 7:20:58 AM | dwg imort problem: arrowheads missing, text jumbled
You will discover that imported and exploded CAD drawings is a BAD practice.  You really want to keep these to a minimum or not at all.  Linking is a much better process or better yet, clean up the detail in a junk REVIT project and then import.  Get rid of leaders - dimensions - hatch patterns and all polylines then revitize what's  laft.
Tue, Nov 17, 2009 at 9:16:56 AM | dwg imort problem: arrowheads missing, text jumbled
ldonkle
Linking the CAD drawing has the same problem.  We have dozens of AutoCAD drawings which we assumed could easily link to Revit...  redrawing each CAD file in Revit is really the best solution?
JUMBLED DWG TEST
Sun, Sep 20, 2015 at 9:21:02 AM
Custom learder arrowheads
Wed, Mar 11, 2009 at 1:55:31 PM
Export to DWG - Text Scaling
Mon, Feb 4, 2008 at 4:01:12 PM
leader arrowheads
Fri, Jul 21, 2006 at 5:30:21 PM
text on plans
Mon, Apr 11, 2005 at 8:42:12 PM
Page generation time: 2.4756
