117 Users Online (114 Members):
Forums >> Revit Systems >> Technical Support >> How to Schedlule Duct Weight
Has anyone had success formulating the Weight of their duct in a Revit MEP 2010 schedule ?
Gary |
I created a total cost parameter which multiplies the Area SF by lbs/sq ft and then $/lb (I went to RS Means for the lbs/sq ft and the $/lb) This is all based on 20 ga galv. stl. So now I am looking into look up tables and csv files so I can provide total cost based on different duct gauges. Am I heading in the right direction w/ look up tables? Or should I have formulas where IF duct length is greater than X feet then use this duct gauge factors. On a similar note my schedule shows each duct size as a single entry, is there a way to combine all similar duct sizes. thanks, gary
Gary |
Duct Fitting Issue |
Tue, Apr 1, 2014 at 1:16:35 PM
Duct won't tap to oval duct. |
Tue, Aug 22, 2017 at 12:38:49 AM
Eccentric Duct Fittings? |
Thu, Dec 15, 2011 at 10:58:31 AM
Autocad MEP duct work question |
Thu, Feb 17, 2011 at 11:12:01 AM
flex duct tag |
Thu, Jun 11, 2009 at 9:27:25 AM
Members: | 2057407 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
