Forums >> Revit Building >> Technical Support >> Mirroring a Baluster
6 Posts No Rating |
Is there an easy way to mirror a baluster end post? This rail has steel angles supporting a cable rail system, and it would be preferable if the angles mirrored. Is the way to do this to create two end posts, a left and a right? Also, is there a good way to trim the cables, which right now are set up as rail profiles, to the end posts? I hope the attached image will clarify things a bit. and thanks to everybody on this forum I couldn't learn this program without it
You will need to create separate post for each end. You can control the point at which the rails end (using the space parameter for the end posts), but it affects all the rail members. You can, however, create a separate railing in the same place consisting of the handrail onlythat extends beyond the end posts.
6 Posts No Rating |
That makes sense to use a separate rail for the handrail, and would not be difficult. As a general Revit question, at what point do you give up on the system family and go for the additional control from a loadable family? It would certainly be more work, but might open up some additional options.
rail 1 and baluster heigth |
Tue, Nov 8, 2011 at 10:40:23 AM
Mirroring |
Mon, Oct 14, 2013 at 4:28:30 PM
custom baluster with decorative piece not staying equal 2019 |
Thu, Jun 14, 2018 at 1:54:48 PM
Need help! Custom baluster |
Mon, Apr 20, 2015 at 7:40:12 AM
Baluster Family Help |
Thu, Oct 16, 2014 at 11:15:49 AM
Members: | 2105148 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
