58 Users Online (56 Members):
Forums >> General Discussion >> Wishlist >> Ceiling tile pattern
It seems to be to be rediculous that the ceiling can have 2 different patterns, one on top, and the other on the bottom. Too often, the pattern is correct in a ceiling view, but then in a 3D view from within the space, they end up wrong. It wouldnt bother me if they both changed as you changed one side, and I kind of understand the reason for two different sided patterns. However, there should be a toggle switch on the ceiling properties to have the top and bottom the same pattern, with the option on as a standard, and the option off to change it as you may want to. Since I need to place light fixtures and air devices on the ceiling from a ceiling plan, it makes sense that the grid will also be designed in this view, moving and rotating as needed. Unfortunately, the other side of the ceiling grid doesnt change.
Rotating CT tile patterns on floors |
Mon, Oct 20, 2008 at 12:15:13 PM
Custom Ceiling Grid |
Tue, Aug 7, 2007 at 2:41:37 PM
Make realistic tile pattern |
Fri, Jun 25, 2010 at 9:43:53 AM
ceiling hatch pattern |
Thu, Apr 17, 2014 at 6:59:10 AM
Tile Pattern Height |
Mon, Oct 9, 2006 at 2:36:02 PM
Members: | 2068325 | Objects: | 23091 | Forum Posts: | 152256 | Job Listings: | 3 |
