27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> monolith stair extra structure material
Wed, Nov 11, 2009 at 11:19:32 AM | monolith stair extra structure material
zulkarneyn
zulkarneyn Avatar
i want to draw a concrete stair but i want to see another material between treads and risers material and conctrete material.i ve added image.red line dosent exist i drawed it, i want to see that line as shows different materials in stairs.
there is a daub between concrete and stones so there must be line for it and a parameter for thickness.
what do you suggest  for it.
Wed, Nov 11, 2009 at 11:45:39 AM | monolith stair extra structure material
Does this really have to be modeled?  2D linework is my suggestion.
Wed, Nov 11, 2009 at 12:34:55 PM | monolith stair extra structure material
zulkarneyn
zulkarneyn Avatar
we can easily do this with structure option at floors why not at stairs.
Wed, Nov 11, 2009 at 12:37:35 PM | monolith stair extra structure material
4 Stars: 203 Votes
Also, if you want to see another material between the concrete and the risers and treads why don't you use a "Filled Region" with the material you want?
Wed, Nov 11, 2009 at 1:02:08 PM | monolith stair extra structure material
zulkarneyn
zulkarneyn Avatar
indeed i am trying to solve this 3 dimentionaly.what if i change the place of section ,section changes then i ve to draw 2d linework again.i am looking for practial solution.it seems stairs didnt developed much more at details since 2009.
Wed, Nov 11, 2009 at 1:29:57 PM | monolith stair extra structure material
Something like this doesn't belong in the stair too.  If you want to model it, do it as an in-place extrusion.
Revit Monolithic Stair with Material Finishes
Tue, Apr 14, 2015 at 6:00:27 AM
extra line monolithic stair and tight railing
Mon, Feb 8, 2010 at 4:36:27 PM
stair anomaly
Fri, Aug 1, 2008 at 9:03:42 AM
13
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:20 PM
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:04 AM
Page generation time: 1.2396
