108 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> issue with copy/monitor of space tags and numbers
![3 Stars: 1 Votes](/images/stars_3.gif) |
I use Revit MEP 2010, and link the architectural Revit model in. After I copy/monitor I can go and "Tag All" using a space tag and retrieve the space name and number from the architects. When they change the name or number of the spaces, it changes on my side as well. The problem is they moved spaces around, deleted spaces, added new spaces, and none of those show up. All the existing spaces are still there, and the names and numbers did update, but no new ones show up. Do I need to do something else to update? Like one problem was a small office area in the middle of a warehouse. The architect moved the office area down a few bays, but the numbers and spaces didnt move with them. I ended up deleting the tags, and maybe the spaces, cant remember. When I hover over the rooms with tags, the outline for the space shows up, there is no outline for the areas where the tags didnt come over after changes. However, if I select the linked model, it clearly shows the spaces witht he X in the middle. How to fix?
![HDDWG2003 Avatar](user_avatar/53352.jpg)
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
DID U TRY AND REDO ALL THE SPACES AND MAKE SURE THE "ROOM BOUNDING" BOX WAS STILL CHECKED IN THE LINK'S TYPE PROPERTIES?
I forgot the step of actually making the spaces. I thought the copy monitor did that. Thanks for the input.
Problem with Copy/monitor of Room tags |
Mon, Dec 8, 2008 at 4:03:30 PM
Copy/Monitor walls |
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue |
Fri, Nov 6, 2015 at 2:16:27 PM
Room Tag Numbers |
Tue, Jul 8, 2014 at 7:22:54 AM
Cant place space tags.. even though some space tags exist.. |
Tue, Feb 9, 2016 at 9:46:47 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
