42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> R-Values for Revit Materials
Tue, Nov 10, 2009 at 11:16:38 AM | R-Values for Revit Materials
cnispel
I am working on a project that I am uploading to Green Building Studio.  I need to know how to input r-values for the materials I am using in Revit.  Does anyone know how to do this?  There are built in r-values for the materials that load with Revit, but can you change these in the properties somewhere?
Tue, Nov 10, 2009 at 11:49:44 AM | R-Values for Revit Materials
3.5 Stars: 395 Votes
I believe you describe the walls when you upload rather than reading directly from Revit.
Preloaded Size Values in Revit MEP
Tue, Aug 24, 2010 at 1:54:48 PM
Material Library with custom parameters.
Fri, May 6, 2016 at 3:36:29 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Importing AutoCAD Linetype Screening Values into Revit
Fri, Jul 27, 2007 at 12:53:09 PM
Combine two text values using a formula
Sun, May 13, 2018 at 5:57:05 PM
Page generation time: 1.9243
