41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall floor connection
Mon, Nov 9, 2009 at 8:33:33 AM | wall floor connection
realrubiks
if I make a simple floor in a new projct say 12' x12', then add 4 walls by picking the edges, how do I unjoin a given wall from the floor, so that I may move it without the floor stretching?
easy one Im sure,  its prolly staring me in the face revit2010 by the way
thanks in advance
rubiks
Mon, Nov 9, 2009 at 8:57:23 AM | wall floor connection
patheh
You should just be able to click on the wall you would like to move and then click the unjoin geometry button and then click the floor that the wall is joined to.
Mon, Nov 9, 2009 at 10:54:16 AM | wall floor connection
realrubiks
thanks patheh, but this did not work...any other suggestions?
Mon, Nov 9, 2009 at 11:22:50 AM | wall floor connection
What patheh should have said was to check this disjoin on the options bar.  Now you can move the wall
BUT ......
This will disjoin every element from the walls - floors - roof - walls - tags - dimensions !
The key here is how Revit builds associations.  If the two items - wall and floor - have common definitions they will associate.   But, if you build the floor without pointing to the wall and dimension it with locks, it will stay in place.
Mon, Nov 9, 2009 at 1:27:25 PM | wall floor connection
realrubiks
thanks wwhub,
but still nothing...I cannont find the 'disjoin' option anywhere when I select the wall
chek attached
rubiks
Mon, Nov 9, 2009 at 1:33:02 PM | wall floor connection
You have to pick the wall then the move - then you will see the disjoin option on your options bar.
Mon, Nov 9, 2009 at 1:45:05 PM | wall floor connection
realrubiks
wwhub
 thanks
that was it, i typically press and drag, which does not give the options....
cheers
rubiks
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Wall and floor connection/cut
Tue, May 8, 2012 at 3:43:26 PM
floor to wall connection detail
Mon, Jan 25, 2010 at 3:04:31 PM
Alternative to a VPN connection for worksharing - Faster remote connection
Tue, Oct 12, 2010 at 8:51:02 AM
revit wall and beam connection
Fri, Jan 9, 2015 at 6:01:21 AM
Page generation time: 1.1777
