Forums >> Revit Structure >> Tips & Tricks >> Exporting Revit to Max
Exporting Revit to Max...this topic is for the newbie...to all the master's please post your reply....thanks...
http://www.rand.com/imaginit/1/rss/viewitem.asp?feedid=BLOGS_VISUAL_ALL&guid=276 I hope it helps...good luck..
Very good info - Thx! but what about export to FBX instead of DWG?
"If you tell the truth, you don't have to remember anything" |
I've had great results exporting an FBX from Revit 2010 into 3DS Max 2010. The file was a large site with multiple massed buildings and topography. I was easily able to move and animate my Revit FBX file in Max. And that after only first playing with Max a month before and working off of a book! Moral of the story: In my limited experience Export an FBX to Max if you need to do walkthroughs/animation. Theyhave the same rendering engine as well, so materials all transfer (except for custom materials and decals). I'm looking forward to playing and learning more in Max!! Tim
I do architecture |
the fbx retains the texture information as diffuse, bumps, cutouts, etc, since it use the same rendering engine ( mental ray) and the same materials (promaterials). You still can edit those materials by clicking the eyedroper button in the material slots of max. it looks better in max, and is faster and it have more customizable settings ( by example i use for all the scenes the draft configuration, but with 5 bounces and the global ilumination on, and "all objects generate and receive gi"button, and gg, the only setting i change is the exposure of mr photographic)
Exporting from Revit and into 3D Studio Max |
Wed, Oct 31, 2007 at 1:25:11 AM
Exporting from Revit to 3D studio max |
Mon, Dec 14, 2009 at 9:11:26 PM
Exporting walkthrough from revit to 3d max |
Mon, Jan 6, 2014 at 3:39:53 PM
Exporting FBX file from Revit to 3Ds Max |
Wed, Sep 30, 2020 at 1:36:49 PM
exporting from revit to 3ds max |
Tue, Apr 20, 2010 at 6:10:21 PM
Members: | 2099050 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
