62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Error message
Thu, Aug 25, 2005 at 4:01:27 PM | Error message
Ivona
Our Revit team is experiencing a problem. We keep getting an error message: Microsoft Visual C++ runtime library runtime error Program :...gram files/Autodesk Revit Building 8.1/Program/Revit exe. This application has requested the runtime to terminate it in an unusual way. Please contact the application's team for more information. The only option we have is to clik OK button and the program closes itself automaticly. Has anyone experienced such a problem? We have contacted the tech support, no solution so far.
Thu, Aug 25, 2005 at 4:43:17 PM | RE: Error message
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I think i've heard of this issue before? Is it occuring on all machines? If its just one, reinstall revit on that machine.
Thu, Aug 25, 2005 at 4:57:38 PM | RE: Error message
Ivona
We have done that, did not work. It has affected all stations (11). We have used back the backup central file from yesterday and it seams that the problem has been solved, but we all lost 5 hrs of our work. The conclusion is that the central file must have been corrupted somehow Post edited on 2005-08-25 17:15:09 Post edited on 2005-08-25 17:15:32 Post edited on 2005-08-25 17:16:15
Thu, Aug 25, 2005 at 6:21:08 PM | RE: Error message
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm. Well make sure you send the corrupted version to the factory so they can do some investigation to prevent it happening again. And if possible recover some of your work.
Thu, Aug 25, 2005 at 6:21:54 PM | RE: Error message
Kezza
Hi, we also had that happening on our machines, came to the conclusion that there was some sort of hardware clash. We upgraded our machines to the HP dual co-processors with 5gb of ram and the problem has since gone away. It reached the point where we would save the jobs every time we moved something or particularly in rendering. That solved our issue. Good luck
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:34 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:49 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:34 AM
Keynotes Error Message
Mon, Jan 24, 2011 at 9:12:18 AM
Error Message
Fri, Feb 18, 2011 at 2:24:26 PM
Page generation time: 0.2980
