57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Section problems
Thu, Nov 5, 2009 at 5:31:31 AM | Section problems
jonezy
guys,
im having a little problem with sections, does the section tool allow you to snap to endpoints and intersections of walls or lines etc.. if not is there a way of getting a section to be parralell on a curved wall
im using 2009
Thu, Nov 5, 2009 at 6:56:16 AM | Section problems
You can't be parallel to a curve.  Do you mean pirpendicular?
Thu, Nov 5, 2009 at 7:02:15 AM | Section problems
jonezy
yes sorry
Thu, Nov 5, 2009 at 7:59:04 AM | Section problems
What I have done but there may be a simplier way....
Draw a line perpindicular to the curved area you want to cut in the correct location for the section.  Cut a section close & beside it and it will assume parallel to the line.  Select the section cut and move... it will allow you to snap to the end of the section cut and you can move it to any point on your line.  Erase the line.
Section problems
Mon, Oct 3, 2011 at 9:56:55 AM
Problems rendering water in section perspective
Mon, Dec 13, 2021 at 2:54:45 PM
Basement section problems
Thu, Feb 9, 2012 at 3:49:45 AM
room tags in section
Wed, Jan 10, 2007 at 11:22:58 AM
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Page generation time: 0.6013
