67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Custom panel family within a curtain system
Tue, Nov 3, 2009 at 10:10:45 AM | Custom panel family within a curtain system
downhill
Good morning,
I made a curtain system by face on a mass.  I'm trying to replace the glass panels with a custom family I made.  When I try to switch them, I just get an error saying "Can't make type".  To switch panels, I pick one, right-click and select all instances then in the properties I switch for my custom panel.
Here is an image of what I am trying to do.  For now the custom panel is just a rectangular panel with an edge offset of 50mm towards the center of the panel.  Eventually it will be fancier.
Thank you
Tue, Nov 3, 2009 at 11:59:11 AM | Custom panel family within a curtain system
cercas
5 Stars: 3 Votes
Maybe your offset, makes your panel is too small in some ocasions..... looks small in top
 - 50mm offset  = if panel is 80mm - 2x50mm offset = -20 = error
 Smile
Joao Cercas
On Revit 2010 (SP3)
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:15 PM
custom shape of curtain panel results in panel replacing
Mon, Apr 12, 2010 at 12:17:29 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:08 AM
Wood Screen - Curtain Panel
Sat, Jan 10, 2015 at 1:44:01 AM
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:13 PM
Page generation time: 1.0801
