33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door angle
Thu, Aug 25, 2005 at 9:12:48 AM | Door angle
jontramos
I am new to Revit. How can I show a door, in plan, at a 45 degree angle? Any help would be nice.
Thu, Aug 25, 2005 at 9:31:10 AM | RE: Door angle
glorybound
You can create a symbolic door swing at a 45 or you could use an angle perameter to change it on the fly.
Thu, Aug 25, 2005 at 2:19:54 PM | RE: Door angle
Xane
Here from family explorer you can download that door ...
Thu, Aug 25, 2005 at 3:35:30 PM | RE: Door angle
jontramos
Thank you both very much. As a new Revit user, I appreciate your patience, and insight. I am sure you (experienced Revit users) get tired of hearing the same easy to solve questions. I do my best to read the forum before asking questions like this, but sometimes is seems that the forum has too much information, and reading thousands of posts is too tedious when trying to get things done quickly. Thanks again.
Thu, Aug 25, 2005 at 4:02:16 PM | RE: Door angle
jontramos
OK, not to be tooooo pickey, but the one(s) that I downloaded from the family explorer we pretty good, but it would be nice if the jamb automatically adjusted to the wall thickness. I have seen doors that can do this, but none of those have the adjustable swing as well. I tried to edit the family, but really, I have no idea how to add those kind of parameters. I truely need to get professional Revit training so that I can learn to make these myself. any help would be good.
Thu, Aug 25, 2005 at 4:42:00 PM | RE: Door angle
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Shouldn't be hard to edit that one to adjust the frame. Edit the frame sketch unlock from the reference plane its constrained to then reconstrain to the reference plane for the exterior/interior face of the wall....
Fully Parametric door with 45 angle swing
Wed, Mar 26, 2025 at 11:13:11 PM
Adjustable angle door family
Thu, May 14, 2009 at 2:30:10 PM
creat double door w/ adjustable swing
Mon, Apr 27, 2015 at 1:30:06 PM
Door angle in plan parameter
Thu, Jul 2, 2015 at 1:22:35 PM
Variable Angle Door Swing breaks at 150°
Fri, Sep 12, 2014 at 4:39:11 AM
Page generation time: 0.7234
