41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Foundation walls & Normal walls joint, linework tool?
Fri, Oct 30, 2009 at 2:47:28 AM | Foundation walls & Normal walls joint, linework tool?
fabioloretti
3 Stars: 2 Votes
Dear revit gurus, I'm quite new on Revit but I noticed that foundation walls and normal walls [or exterior walls] can't be joint and they always show a line between them in isometric, elevations and perspectives. Using the linework tool wasn't very practical since I have to do it on all the views, one by one. Usually 4 elevations, 1 or 2 isometrics and many perspectives! Stacked walls don't really solve the problem as I have many diferent slab levels, etc... How would you guys do it? Thanks in advance.
Fri, Oct 30, 2009 at 2:50:30 AM | Foundation walls & Normal walls joint, linework tool?
fabioloretti
3 Stars: 2 Votes
Sorry for my poor english, "can't be joined" instead of "can't be joint".
Fri, Oct 30, 2009 at 4:28:55 AM | Foundation walls & Normal walls joint, linework tool?
4 Stars: 202 Votes
Did you try the "Join Geometry" tool??
Fri, Oct 30, 2009 at 4:39:26 AM | Foundation walls & Normal walls joint, linework tool?
fabioloretti
3 Stars: 2 Votes
I did. It doesn't work either.
Fri, Oct 30, 2009 at 9:47:59 AM | Foundation walls & Normal walls joint, linework tool?
Cut a section .... are you sure they line up?  Is the brick in the same zone (finish not core)
Sat, Oct 31, 2009 at 4:11:39 AM | Foundation walls & Normal walls joint, linework tool?
PedjaCh
Your foundation walls is probably set to "Bearing" and normal walls is set to "Non-bearing".
Set them all to "Bearing" or all to "Non-bearing", or, even better all to "Structural combined" (Instance properties of the wall - Structural)
Sun, Nov 1, 2009 at 12:24:19 AM | Foundation walls & Normal walls joint, linework tool?
fabioloretti
3 Stars: 2 Votes
Man, that was the exact problem. Thanks so much, PedjaCh! I really appreciate. :-)
Foundation walls in elevation
Sun, May 22, 2005 at 8:46:50 PM
joined walls in elevation
Wed, Sep 22, 2010 at 10:25:33 AM
Foundation walls / vs slab edge sweeps
Wed, Nov 8, 2006 at 6:10:44 PM
Foundation Walls not mitering?
Fri, Jan 25, 2008 at 9:10:53 AM
Tiles Lines between 2 walls
Tue, Dec 29, 2015 at 10:33:59 AM
11
Page generation time: 1.3872
