121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> %%d ? what happened?
Wed, Oct 28, 2009 at 10:25:24 AM | %%d ? what happened?
HGL5
If I want to do a degree symbol or diameter symbol or +-, how do I do it in revit 2010? It doesnt seem to work like in AutoCAD. THanks for anyhelp
Wed, Oct 28, 2009 at 11:35:06 AM | %%d ? what happened?
From the start menu, I select run, and type in charmap.  This GUI allows you to select your font style and see all the characters.  Select the character and it copies to your clipboard, then within the text line, select paste from the ribbon.
Wed, Oct 28, 2009 at 1:40:54 PM | %%d ? what happened?
tim123
4 Stars: 19 Votes
You can also use the Alt codes for the more common ones, such as Alt+ 0178 (²Winking, Alt+ 0179 (³Winking, Alt+0216 (ØWinking, Alt+0176 (°Winking.  I keep a little list of the ones that I use frequently next to my desk to remind me.
Wed, Oct 28, 2009 at 1:42:59 PM | %%d ? what happened?
HGL5
hmm.. seems odd that a shortcut does not exist in Revit. Also I coule not find the diameter character in charmap. I was looking in Arial btw. Thanks for the info WW
Wed, Oct 28, 2009 at 1:48:18 PM | %%d ? what happened?
HGL5
Oh.. how do you use the alt codes? In 2010 when I press alt + numbers I begin to activate commands on the ribbon.
Wed, Oct 28, 2009 at 1:55:37 PM | %%d ? what happened?
tim123
4 Stars: 19 Votes
You need to be in the text editor (don't actually press +).
Wed, Oct 28, 2009 at 2:26:48 PM | %%d ? what happened?
ARiel has it... the latin O with a stroke is what everyone uses.
Wed, Oct 28, 2009 at 3:01:36 PM | %%d ? what happened?
HGL5
I had to do alt commands in notepad, won't work inside revit.  Thanks for the help, at least I got a work around to work=)
Wed, Oct 28, 2009 at 3:36:16 PM | %%d ? what happened?
tim123
4 Stars: 19 Votes
Works for me in 2010, although at one stage it didn't. After restarting Revit it worked fine.  I'm not sure if the update addresses that, but I haven't had any trouble with it lately.
Wed, Oct 28, 2009 at 5:08:10 PM | %%d ? what happened?
HGL5
Really? If I try and do a diameter symbol I end up saving my project =( while in text edit box I hold alt then press 0 (nothing yet... 2 boom saves my document I cant get past 2 in the alt + 0216 command because I end up saving.
Wed, Oct 28, 2009 at 6:15:19 PM | %%d ? what happened?
#11
HGL5
DOH! you need to use the numpad, not the top number keys...
What happened to C4R Communicator?
Fri, Aug 16, 2019 at 10:12:10 AM
What's happened to the RevitCity site?
Tue, Sep 18, 2007 at 10:11:28 AM
erasing object in REVIT 2008, but did not really erase
Wed, Oct 10, 2007 at 10:28:22 AM
What happened to Curtain system by lines command?
Wed, Jun 17, 2009 at 1:47:01 AM
Floor Visibility overiding everything else....
Wed, May 26, 2010 at 3:46:02 PM
Page generation time: 0.7997
