61 Users Online (60 Members):
Forums >> Revit Structure >> Technical Support >> Custom slab modelling issues
22 Posts No Rating |
Good morning guys and girls I'm in need of a little assistance fairly urgently. I'm modelling up a slab, fairly simple, but I cant get it to provide any inpormation in the schedule. The slab itself is shaped so I had to produce it a a component as I couldn't think how esle to do it. I've now modelled it as a mass but still no luck, any chance one of you guys can take a look and tell me where I'm going wrong please? This is my first major attempt at Revit so still learning... Many thanks Adam
Sorry, forgot to attach file
HI Adam, I guess I need a bit more information form you. What type of schedule are you doing, and just by looking at your floor, there is no information to the type parameters. Fill some of those out first then create a floor scheduole with the fields needed IE. Type Mark Type Comments Cost Assembly Code Description and so on.
Welcome to the REvitlution!!! |
Thanks for the response. My schedule at present should show; area perimeter volume family and type level There could also be the possiblity of additional columns in the schedule. I'm having trouble with how to set the parameters up in Revit. Unfortunately we dont use the program that often and then when we do its a mad rush to try and work out how to do things, any guidance would be very much appreiciated. Adam
Adding Reinforcement to a Custom Slab Thickening Family |
Fri, Apr 30, 2010 at 12:27:08 AM
Slab vs. Floor vs. Foundations...Which do I use? |
Mon, Feb 18, 2008 at 2:49:13 PM
Slab tag positioning |
Thu, May 14, 2015 at 8:43:38 AM
Creating a structural slab for analysis |
Tue, Jun 5, 2007 at 5:08:16 AM
thickend slab |
Tue, Apr 7, 2009 at 4:52:23 PM
13
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
