55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> External Lighting Night Scene
Sat, Oct 24, 2009 at 7:56:12 AM | External Lighting Night Scene
SimonBea
Hi Everybody, have been reading Revit City for a while but only just got around to registering.
I'm having an issue when trying to render a night scene. I have a building modelled with a section of glass front and a combination of lights inside and some external lights.
 I am trying to render a night image of the scene so to do this I have adjusted the sun and shadow settings so that the time is approx 7pm and have changed the lighting scheme to Exterior sun and Artificial Lighting and have checked that the artificial lights are all ticked.
The above doesn't seem to be working at all, as far as I can make out there is no light emitting from any of the lights. I did a trial render with the time at midnight so the scene was a lot darker and there was a tiny amount of light coming from the lights, nothing like the effect I was after.
 Is there a setting im missing or how do I increase the lighting amount?
 Many Thanks for any help.
Simon
Sat, Oct 24, 2009 at 8:09:26 AM | External Lighting Night Scene
SimonBea
Revit 2009 by the way
 THis is the type of effect I'm after
http://www.revitcity.com/gallery.php?action=view&gallery_id=10671
Edited on: Sat, Oct 24, 2009 at 8:27:42 AM
Sat, Oct 24, 2009 at 8:49:47 AM | External Lighting Night Scene
4 Stars: 203 Votes
First Welcome to Revit World....
If you check there are a "tiny amount of light coming from the lights" pick in one light, go to the properties, edit/new and in the bottom you have the "wattage" increase that 10, 100, 1000 times until you have the effect you want...
BTW, after the render you have the "Exposure control" where you can "smooth" the image....
Edited on: Sat, Oct 24, 2009 at 8:51:16 AM
Sat, Oct 24, 2009 at 9:09:53 AM | External Lighting Night Scene
SimonBea
Thanks!
 I actaully manged to achieve the right effect by in the render diag changing it to artificail lights only and then setting the backgroudn colour to a dark blue. HOwever it would be nice to do it still with a cloudy night sky so i'll give your suggestion a go.
Many Thanks
Mon, Oct 26, 2009 at 2:09:22 AM | External Lighting Night Scene
tim123
4 Stars: 19 Votes
You should be able to do it by turning the lights down quite low and then adjusting the exposure afterwards.  The attached image was set to sun and artificial lights and the time set to about midnight.
lighting glitches on night scenes
Wed, Aug 10, 2005 at 4:29:34 PM
lighting scheme and artificial lights
Mon, May 19, 2008 at 9:21:47 PM
Night Scene Render
Wed, May 2, 2007 at 9:21:18 PM
Rendering Night Scene 2009
Mon, Apr 27, 2009 at 12:20:13 PM
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:49:56 PM
Page generation time: 0.3796
