42 Users Online (41 Members):
Forums >> General Discussion >> Revit Project Management >> Detail levels and dimensioning
8 Posts No Rating |
In my office we have been discussing the best way to build our walls and dimension them. We always dimension stud to stud, and so far we have just been building our wall types omitting any finishes (gyp, tile, panels, etc.) This way it is easy to dimension and logical for the contractors. However, in our discussion we determined that it would be nice if in interior elevations, for example, the ACTUAL thickness of the walls were shown so as to show true interior room dimensions. This would be most relevant when placing casework from wall to wall where if the finishes are not shown you would have to be very careful about knowing how thick your finishes are and leaving enough space to accomodate this. Is there a way to see in plan only the studs thickness (3.5" for example) and other views or detail levels see the true wall thickness?
This is Revit - Not CAD. Model it correctly ... stud with finishes. You can still dimension to stud... even in coarse view!
Detail levels |
Sun, Nov 20, 2005 at 4:00:07 PM
Dimensioning to the centerpoint of an arc |
Tue, Jul 29, 2008 at 4:11:55 PM
Best Approach to Levels? Construction or finish |
Mon, Sep 22, 2014 at 10:43:18 AM
Multiple detail levels of walls in same view |
Fri, Nov 28, 2014 at 9:51:04 PM
Can I set text visibility to hide/show at different view detail levels? |
Tue, Sep 15, 2009 at 6:56:43 AM
Members: | 2019243 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
