52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Columns/Beams won't cut wall & wall beyond is visible
Thu, Oct 22, 2009 at 11:43:50 AM | Columns/Beams won't cut wall & wall beyond is visible
crockett3030
In Revit 2008, I have beams and columns (structural) that don't cut the wall that they are located within, and the wall beyond is visible inside the beam/column.
Is there a way (short of drawing a million masking regions) to make the interior of the beams/columns solid or interrupt the walls.
 Also, in the plan view, I can't get the wall that tees off to clean up with the main wall.
 Any help is greatly appreciated.
Mon, Oct 10, 2011 at 1:56:08 PM | Columns/Beams won't cut wall & wall beyond is visible
jscalfano
Did you ever find a solution for this?
Tue, Feb 28, 2012 at 4:26:13 PM | Columns/Beams won't cut wall & wall beyond is visible
jazzielover
Need solution too !!!
Don't know why anybody thinks that concrete beams and colums have a lower rang than bricks.
can't get my beams /walls and colums like i want 2
Thu, Jun 21, 2012 at 9:12:05 AM | Columns/Beams won't cut wall & wall beyond is visible
alexandredav
THE BEST SOLUTION I HAVE COME UP WITH IS TO SET THE A SOLID HATCH IN CUT PATTERNS FOR THE BEAMS...
THAT WAY WHEN IT IS CUT THE PATTERN WILL COME IN FRONT OF REST.
REVIT STILL CAN LEARN SOMETHING FROM AUTOCAD, ONE OF THEM IS DEFINETELLY IN FRONT OF, ABOVE OF COMAND....
Thu, Jun 21, 2012 at 9:19:32 AM | Columns/Beams won't cut wall & wall beyond is visible
jazzielover,
Do you own the wall or is it a linked model?
More information would be helpful.  You tagged this on a Revit building thread but are you structural?
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:12 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:16 AM
RAC 2009 Columns, Beams & Walls.
Fri, Sep 26, 2008 at 10:41:22 AM
Voids won't cut wall
Mon, Aug 25, 2008 at 12:16:37 PM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:12 PM
12
Page generation time: 1.2310
