58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> printing in revit
Thu, Oct 22, 2009 at 9:21:50 AM | printing in revit
jetfavre
I know there isnt a answer to this but.... I CAN'T I PRINT TO A SCALE IN REVIT??? VERY FUSTRATING!!!!
everything about this program is great except the printing issue. to simple, not enough variables, I cant print a view to a scale. why why why!!!!
Thu, Oct 22, 2009 at 9:42:14 AM | printing in revit
Bronsart
I agree the print menu in CAD is a lot better than REVIT.  For instance, I really miss the print "window" option.
There are two ways you can print to a scale.  First is to change the scale of your view prior to printing.  This works as long as you do not have any annotations that will change size (relative to the drawing).
Second is to change the zoom percentage in the setup menu.  You'll have to calculate what the percent of change is from your view scale to your print scale.  Example:  If your view is at 1/4"=1'-0" and you want to print at 1/8"=1'-0", then you would change your zoom to 50%.  If it is anything more difficult than that, wait until you've had a couple more cups of coffee...
BTW... I'm using 2009
Mike
Thu, Oct 22, 2009 at 9:59:03 AM | printing in revit
jetfavre
Thank you and i understand that.
question.. when i put a border in revit is it "Full scale" or is it scaled? I know I still think in autocad but after 15yrs its a little hard.. i think that is what is messing with me.
Q: can i scale the border in revit??
Thu, Oct 22, 2009 at 10:06:36 AM | printing in revit
Bronsart
I am not completely understanding your question.  I am assuming that what you mean by border is a titleblock.  Are you printing from a sheet or a view?  Either way, if you change the zoom percentage (50% for example) it will scale everything that is being printed.
Mike
Thu, Oct 22, 2009 at 10:26:33 AM | printing in revit
jetfavre
THANK YOU.
WHAT I MEANT WAS TITLEBLK. AND I AM PRINTING FROM A SHEET.
THATS FINE. ILL DEAL WITH IT,  I JUST SEAMS ALITTLE WEAK TO HAVE SUCH A GREAT PROGRAM WITH LOUSY PRINTING FREATURES.. HOPEFULL THEY WILL CHANGE THAT.
THANK YOU AGAIN.
Printing Query
Wed, May 23, 2012 at 7:54:08 AM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
printing press
Wed, Dec 29, 2010 at 11:28:44 AM
Printing Lighting Plans in Revit MEP
Mon, Mar 14, 2011 at 9:20:35 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
18
Page generation time: 2.1940
