69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> 2 Mile Radius Error
Wed, Oct 21, 2009 at 5:01:40 PM | 2 Mile Radius Error
jhayden
jhayden Avatar
Almost everytime I link a CAD file into revit, I get the 2 Mile Error. The CAD file gets exploded, purged, audited, centered on 0,0, the whole nine yards, and I still get this error message. There should be a way around this or a better way to link/insert files into revit.
Wed, Oct 21, 2009 at 10:42:30 PM | 2 Mile Radius Error
lunchtrayrider
3.5 Stars: 7 Votes
out of curiosity, i'm assuming your getting the file from someone else, do you copy the lines out of one cad file and then paste it into a fresh one be fore you link it?
I like scooters. and motorcycles.
Thu, Oct 22, 2009 at 9:03:37 AM | 2 Mile Radius Error
jhayden
jhayden Avatar
Usually what I do is delete all xref files, unlock, thaw and turn on all layers, delete unnecessary lines that may exist way off in model space, audit, purge layers, regen, re-check zoom extents, then make a block out of the drawing selecting left to right. I'll open the block file, and make sure there isn't something I missed, then link or insert the block file into my revit model.
I think the problem is where it gets inserted, possibly 2 miles away from the model. If I could choose my origin using a point (like in CAD) then select where I want the link to be located in the model, things would be alot smoother. I have used the manual options when inserting the file as well.
Thu, Oct 22, 2009 at 10:02:05 AM | 2 Mile Radius Error
Bronsart
This is probably not it, but it's easy to check.  Check your insertion base point in your CAD file.
Type "INSBASE" and set it to (0,0,0).  Revit might be trying to use this point when inserting.  Let us know if this works.
Mike
Thu, Oct 22, 2009 at 10:07:23 AM | 2 Mile Radius Error
jhayden
jhayden Avatar
Thanks, I'll definitely try that out
Wed, Dec 2, 2009 at 11:29:14 PM | 2 Mile Radius Error
Juzza
Juzza Avatar
Hey mate, I've had this issue before. It happens when you get your import scales way out of whack. Generally I scale the cad file to the units I will use them in Revit (millimeters for me) then when importing I select the same units on the Link Cad Formats box. This way your importing on a 1:1 basis & should never have the problem again. Smile
Revit-Autocad Import/Cad Resolution problems
Tue, Aug 11, 2009 at 2:57:21 PM
Export to DWG - Text Scaling
Mon, Feb 4, 2008 at 2:57:43 PM
Stair Rail Error
Thu, May 9, 2013 at 7:30:00 AM
Need help creating a sloped slab with Radius Edge
Tue, May 2, 2006 at 5:23:53 PM
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:05:52 AM
Page generation time: 0.6470
