135 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> In Place furniture not cutting
Wed, Oct 21, 2009 at 11:34:32 AM | In Place furniture not cutting
RNLRNL
I have created an in place shop counter as a furniture component and now want to create a section though it but the section isn't cutting it - instaed I am getting an elevation of this piece of furniture. Is there a setting to allow a section to be cut through a piece of furniture/
Thanks
Wed, Oct 21, 2009 at 11:46:32 AM | In Place furniture not cutting
RstredS
Make sure it is in the correct category.
 I once made a fascia, in the category "Light fixtures" and it wouldn't section.
Wed, Oct 21, 2009 at 11:46:54 AM | In Place furniture not cutting
4 Stars: 202 Votes
"Furniture" is a NON-CUTTABLE family, check in the HELP menu what is Cuttable and Non-cuttable families....
Wed, Oct 21, 2009 at 12:10:46 PM | In Place furniture not cutting
RNLRNL
Now that I have created the counter as a piece of furniture is there anything I can do i.e. change its category etc which will allow me to cut the section through it?
Wed, Oct 21, 2009 at 12:16:47 PM | In Place furniture not cutting
4 Stars: 202 Votes
Settings>Family category and parameters then select one family CUTTABLE
Wed, Oct 21, 2009 at 4:15:20 PM | In Place furniture not cutting
RNLRNL
Thanks - perfect that did the job - I changed the item to casework and it now cuts fine. Do you think it makes any difference now that it is categorised as casework rather than furniture?
Wed, Oct 21, 2009 at 4:55:12 PM | In Place furniture not cutting
Sure does if your like us.  Furniture is turned off in architectural plans by VG..... Here is a hint at how to get around this.  Make it a subcategory of furniture.
Furniture, Doors, Casework, In Place Components have x-ray, see through properti
Wed, Jan 25, 2012 at 4:07:11 PM
Cutting Section through Furniture Family
Thu, Oct 29, 2009 at 6:37:48 AM
In Place Furniture Family will not schedule to its reference level
Tue, Mar 27, 2012 at 1:51:26 PM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:34 PM
Furniture Visibility
Mon, May 21, 2012 at 11:33:49 AM
Page generation time: 1.8286
