45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Profile Family (Can't create instance)
Wed, Oct 21, 2009 at 10:31:54 AM | Profile Family (Can't create instance)
LisetteTerry
LisetteTerry Avatar
Hi I am using REVIT Structure 2010.  Has anyone ever had issues with being able to create an instance of a profile family within a project?  I created a profile family (one type) with quite a few instance parameters.  It flexes fine within the family.  I loaded it into my project and it shows up in the project browser.  When I look at the properties I can preview the shape of the profile and it is there.  The problem is when I go to create an instance it is greyed out and will not let me place it in the model.
I created the profile using reference planes (with labeled dimensions) and model lines that are locked to the reference planes.  One more question, I was initally attempting to use this profile family to create an in-place family swept blend.  I wanted to use the profile family as the profile shape of the swept belnd.  Is this the right way to go about this?  (I attached a jpg of the profile family)
I appreciate your help!
Lisette
Life is not always linear...
Wed, Oct 21, 2009 at 11:32:22 AM | Profile Family (Can't create instance)
Did you define the usage of the profile?
You can read about that and then how you can use these profiles in your HELP.  Just use the HELP search feature and "profile" to see the available topics.  One topic is how to use a profile in a swept blend.
Wed, Oct 21, 2009 at 11:39:04 AM | Profile Family (Can't create instance)
LisetteTerry
LisetteTerry Avatar
Thank you!  I have my question answered.  There was a little piece of a corner in the profile that was not connected, causing it to not be a closed loop and therefore would not do a swept blend.  Also I was trying to place the profile before selecting solid --> swept blend.  Now I know NOT to do that.  Smile
I appreciate the quick response though.
Lisette
Instance profile parameters?
Fri, Nov 6, 2009 at 2:43:12 PM
Can't change Instance's Family. Try changing Instance's Host to a Level first.
Mon, Oct 3, 2005 at 9:29:33 AM
adjustable profile family
Fri, Jul 20, 2012 at 9:08:25 AM
Wall Sweep profile family problem
Tue, Oct 2, 2012 at 6:41:22 PM
Detail Component in Profile Family - Doesn't Work = Why?
Tue, Dec 22, 2015 at 1:45:50 PM
Page generation time: 1.9733
