Forums >> Revit Building >> Technical Support >> Materials / Rendering help
5 Posts No Rating |
This is my first post here so please bear with me. I am still having trouble after following this tutorial: http://revitcity.com/tutorials/how_to_grow_your_family/ I followed it exactly, but when I render, all the materials still appear to be the same washed-out greyish default material. What could possibly be the problem?
There are thousands of threads like this in the forum, if you search you go find them... see this one: http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
Edited on: Wed, Jun 30, 2010 at 6:11:30 AM
This sounds like you are using a CAD drawing - right? Two mpossible problems: - You need to understand how Revit assigns materials. The first rule to learn is that the project RULES. Once a material is assigned in the project, it always governs the element - no matter how often it is changed in the family. (So, in you case - did you try to change materials in the family after you had already loaded the family?)
- Cad materials are assigned by layer. In your project, look under settings/object styles/Imported objects/imports in families and adjust your materials.
5 Posts No Rating |
Thanks for the reply. I would have gotten back sooner but my email alerts were not configured. Still not having any luck. I think it will help to have a specific example. I have a cad file that is a model of an umbrella. I want to have a material for the wood pole, the top fabric part, and the metal components. I included screens, the cad file, and a small revit file.
5 Posts No Rating |
I wanted to address WWHub's post: 1) I have changed the materials in the family, and tried adjusting them in the project, doesn't seem to make a difference 2) Tried going to settings/object styles/Imported objects/imports and adjusting materials here also
Ok, see the video: http://screencast.com/t/j63SeIje
5 Posts No Rating |
Thank you Typhoon, I am now having success with this.
1 Posts No Rating |
It seems the video you have posted typhoon has worked for many people, but this video is not available. anyway to repost a new link to it?
This afternoon if i have time i post a new video....
"Jbarret" try this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
Edited on: Wed, Jun 30, 2010 at 6:12:42 AM
Rendering Materials |
Wed, Sep 13, 2006 at 1:13:07 PM
Revit materials missing at rendering [ 1 2 ] |
Tue, Jun 14, 2011 at 11:24:22 PM
22
Revit Custom Materials Rendering Objects invisble |
Mon, Mar 14, 2011 at 10:42:56 AM
13
some materials not rendering in perspectives |
Thu, May 23, 2013 at 3:00:35 PM
rendering issue |
Mon, May 21, 2007 at 1:39:09 PM
Members: | 2115418 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
