Forums >> Revit Building >> Technical Support >> Phasing and Phase Names
4 Posts No Rating |
I am working on a renovation of an existing building and the Owner has asked us to divide the project into three options, or phases. The first two options split the work about in half, and Option 3 is to do all the work at once. What is the best way to phase this documentation? We need to be able to show an existing, demolished and new scope of work for each option, and I don't want to "overmanage" this process.
I would probably do this as design options rather than phases for the new work. The demolished would still be a phase. Then depending on what he choses, you show DO 1 or DO 1 & DO 2 or DO 1,2&3.
4 Posts No Rating |
What is the difference between design options and phases?
Best answer .... read your HELP to see how design options work.
Design option in my oppintion are more like linked models. You have what is called the "main model" think of these as the exterior walls. Then with the main model there are "design options". Think of this multiple floor plan designs within the exterior walls.
J. Allen Ball Revit Architecture 2010 Certified Professional |
Phase: the time line of the building eg; how the site is now, new additions, future work... Options: different ways the design can go eg; when you have a client who wants either two new bedrooms on the second floor or three new bedrooms or maybe...
Display Phase I & Phase II Room Names Together |
Fri, Jan 11, 2013 at 2:53:40 PM
transferring room names form one phase to thenext |
Thu, Sep 12, 2013 at 2:32:15 PM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:57 PM
Phase Graphic Overides |
Tue, Sep 18, 2018 at 8:42:54 AM
phasing |
Mon, Feb 24, 2014 at 1:36:13 PM
Members: | 2105217 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
