84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 11:57:39 AM | Linked DWG Files not visable in RCP
aangle
I have lighting layouts completed in DWG and would like to link those files into my revit file to use as an underlay to place in revit ligthing fixtures.  But the DWG file is hidden by the ceiling grid in revit, I can't bring the DWG to front so how do I get the DWG visable through the revit ceiling gird?
Mon, Oct 19, 2009 at 1:29:15 PM | Linked DWG Files not visable in RCP
Bronsart
You have to make sure your imported dwg is at a level between your cut plan and ceiling level.  Your model is covering up the dwg objects.
Changing you electrical plan to wireframe would also work if it does not get too congested.  After you layout your lighting, just change it back to hidden line.
Mike
Mon, Oct 19, 2009 at 1:37:26 PM | Linked DWG Files not visable in RCP
aangle
Thanks, I just changed to wire frame and I can see all the dwg now, are the revit fixtures going to still cut into the ceiling plane?
Mon, Oct 19, 2009 at 1:46:59 PM | Linked DWG Files not visable in RCP
Bronsart
They should if your fixtures are a ceiling based family.  I would throw a couple fixtures into your model & cut a section to make sure they are at the level you want.
 Mike
Exterior walls not visable
Mon, May 11, 2009 at 5:28:24 PM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:44 AM
Overlays in Linked .dwg Files Showing Up in Revit 2013 Views
Wed, Sep 26, 2012 at 9:22:02 AM
Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:07 PM
Managing big linked files and exporting to 3ds max
Tue, May 11, 2010 at 8:06:16 PM
Page generation time: 2.4347
