63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Materials of Imported DWG files
Sat, Oct 17, 2009 at 3:12:02 AM | Materials of Imported DWG files
olavana
Hi,
I'm new to Revit and am completing a uni project in it. I've imported some DWG files from skethup into my revit file, which has seemed to work fine. Though, when I render, all of the imported objects are rendering grey. I've tried changing the colour import settings between invert and preserve, which changes the colour of the object 'in model', but the renders are still coming up grey for both.
Any help anyone could provide would be much appreciated!!
Thanks,
Alyce
Sat, Oct 17, 2009 at 3:43:24 AM | Materials of Imported DWG files
olavana
I've had a look at similar posts and have tried to adjust the layers under object types, but only two out of ten components seem to be working. Does anyone know why this is happening? I've tried changing the materials to the same as the ones that are working and it still doesn't work. When I extend the object list, each component only has about 2 different layers.
Please help! Thanks Smile
Sat, Oct 17, 2009 at 3:48:45 AM | Materials of Imported DWG files
olavana
Sat, Oct 17, 2009 at 4:13:48 AM | Materials of Imported DWG files
olavana
Sat, Oct 17, 2009 at 3:47:09 PM | Materials of Imported DWG files
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"I've imported some DWG files from skethup into my revit file...." , look at this post, It could be useful for you....
http://www.revitcity.com/forums.php?action=viewthread&thread_id=18203&start=15
Imported dwg files
Wed, May 10, 2017 at 10:25:30 PM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:12 AM
Corrupt Imported DWG files
Wed, May 10, 2017 at 10:49:30 PM
EXPLODING IMPORTED FILES
Tue, Oct 17, 2006 at 2:01:21 AM
Dwg to RFA and Materials.
Sun, Feb 2, 2014 at 1:40:55 PM
Page generation time: 1.1908
