37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Angular surfaces
Fri, Oct 16, 2009 at 11:35:55 AM | Angular surfaces
Rayk123
What is the best way to develop angular surfaces?
In Inventor and Solid Works you can creat sketch planes anywhere you want. In Revit you seem limited to vertical and horizontal placements on existing surfaces.
Fri, Oct 16, 2009 at 11:48:42 AM | Angular surfaces
You can create reference planes in Revit as well.  If you are using 2010, there are all sorts of conceputal massing tools as well.
Fri, Oct 16, 2009 at 11:54:33 AM | Angular surfaces
Rayk123
I am using revit structure 2010 and use the mass quite a bit to develop my projects.
But how do I get to make reference planes?
Fri, Oct 16, 2009 at 1:25:29 PM | Angular surfaces
In either the family editor or in the main model for an in-place family, the reference plane option becomes available.
Fri, Oct 16, 2009 at 2:23:30 PM | Angular surfaces
Rayk123
thanks for your help WWHUB, very much appreciated....
showing angular dimensions in degrees seconds etc
Wed, May 5, 2004 at 7:43:16 AM
ANGULAR DIMENSION TOLERANCE
Mon, Mar 2, 2015 at 1:00:50 PM
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
How to take quantities from painted surfaces?
Tue, Oct 10, 2017 at 1:00:43 AM
Angular parameters
Tue, Sep 3, 2013 at 8:14:08 AM
Page generation time: 1.0952
