140 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Custom Grid Heads
Tue, Oct 13, 2009 at 1:25:05 PM | Custom Grid Heads
feliss
I'm trying to customize a grid head, but it seems that the grid head doesnt connect with the grid line.  (see fig 1)
if i adjust the family, and move the grid head up/down from the centrepoint, (fig 2) and then load into project..
the grid heads move right out of place.. on both axis. Cryingfig 3)
Tue, Oct 13, 2009 at 1:27:02 PM | Custom Grid Heads
feliss
using revit 2008 for now..
Mon, Dec 20, 2010 at 2:36:44 PM | Custom Grid Heads
pdoug
3 Stars: 2 Votes
I know the original post was over a year ago - but I was searching for a solution to the same problem.  After coming up with very little information I decided to try harder at figuring this out.  Hopefully you found a solution prior to this, but if not - here's what I came up with...
In your grid head family draw the irregular shape or any shape other than a circle you desire, add the label, then draw a circle encompassing your non-circular shape.  Make this an invisible line and you're good to go.  The gridline in your project will now cut to your irregular shaped grid head.  See attached pic...
Hope this helps!
Tue, Apr 26, 2011 at 6:38:24 AM | Custom Grid Heads
pdoug
3 Stars: 2 Votes
Hey all!
I wanted to submit a follow-up to my original response post.  As the above works like a charm in plan view - it doesn't work the same way in a section view.  I have attached pics as well as the family file in hopes someone with more knowledge can help me out!  I would be interested in either knowing why a section view would alter the rotation of the text in the family file...or maybe there is something else I am missing.
Thanks!
Tue, Apr 26, 2011 at 6:39:34 AM | Custom Grid Heads
pdoug
3 Stars: 2 Votes
pics attached this time (hopefully!)
Tue, Apr 26, 2011 at 6:43:56 AM | Custom Grid Heads
pdoug
3 Stars: 2 Votes
ok last attempt at attaching the pics...
scaling of level head, grid heads etc
Thu, May 25, 2006 at 6:07:38 PM
Grid-head sizes set to be view specific?
Wed, Jun 1, 2011 at 10:15:23 AM
display levels on grid heads
Thu, Jan 24, 2013 at 4:27:07 AM
Grid Head/lines in Call Out Views
Sun, Dec 3, 2006 at 5:38:38 PM
CUSTOM KEY NOTE TAGS/ ROTATING VIEWS IN PLOT SHEETS
Thu, Feb 6, 2014 at 2:16:37 PM
Page generation time: 0.4032
