61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dividing a building up between multiple offices - Any advice welcome
Tue, Oct 13, 2009 at 11:39:36 AM | Dividing a building up between multiple offices - Any advice welcome
jimij
Okay, so we have a large, (100,00 sf) 4 story U-shaped building that we are working on with another office. The "plan" is that our offices would collaborate on SD (done, mostly) and their office would take 80% of DD and we would handle 20% of DD and all (or most) of CD. We're trying to work out how we should divide worksets and or links, should we:  A)   Try and split the building up via worksets and put the central on an FTP site (seems slow and dangerous)  B)   Split the building into linked files, Shell and Core (we take Core, they take Shell, and have separate inter-office worksets for our own workflow)  or  C)   Split the building into linked files based on building "parts" (they take two parts of the 'U' we take the other)
Has anyone dealt with a similar problem? Any ideas or feedback is welcome, Thanks in advance!
Edited on: Tue, Oct 13, 2009 at 11:44:06 AM
Thu, Oct 15, 2009 at 12:53:11 AM | Dividing a building up between multiple offices - Any advice welcome
eldados
eldados Avatar
4.5 Stars: 8 Votes
hey,
avoid trying to use different worksets method, it's very messy.
the best option for you guys will be to divide the building as in your option B, treat the other office like you would an external consultant and just link eachother's files...
Integrator
KarelCAD
Thu, Oct 15, 2009 at 9:13:24 AM | Dividing a building up between multiple offices - Any advice welcome
You are going to find that there is no easy answer to this.  If you use linked files, you can't cross the boundry for view references.  In addition, even though all elements can schedule in one file, they can't be cross tagged.  So the consequence is do you keep seperate sheets and plot from two files?
Sorry, but I think you do use worksets but you really have to work at it.  The shell should be in one worset and only one office controls it.  The interior elements could be broken up by levels and each office works on seperate levels.  Views too would be "assigned" to the correct office.
Really all gets very messey.
Multiple Building Project. Need advice.
Tue, Oct 13, 2009 at 10:28:33 AM
dividing project and linking files : structure, interior/envelope walls
Wed, Apr 6, 2005 at 6:22:49 PM
Central File Access From Multiple Offices
Wed, Aug 20, 2014 at 10:01:51 AM
2 offices connected by a sky bridge
Mon, Mar 31, 2014 at 7:55:45 AM
One Building Multiple Jobs
Tue, Oct 12, 2010 at 11:26:54 AM
Page generation time: 0.6425
