66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Attaching beams to model by face roofs - limitations?
Tue, Oct 13, 2009 at 11:03:13 AM | Attaching beams to model by face roofs - limitations?
robrevit2009
Hi all
Just testing the limitations of working structurally with roofs created using mass and the Model by Face method.
I want to attach a steel beam to the roof.
I believe that I can attach a beam using the pick line tool for the edges of a roof to match the profie of a roof, but not internally like you can an extruded roof.
Are there any known work arounds to this? Can I have a beam system that attachs to the underside of a roof that has been formed by creating a mass and then a roof using the model by face tool? For a reason for why we may do this, consider the profile of a bowl stadium and the structure that supports the cantilevering roof.
Any help, greatly appreciated.
Tue, Oct 13, 2009 at 11:07:17 AM | Attaching beams to model by face roofs - limitations?
robrevit2009
Should have said. I'm using Revit Structure 2010.
Tue, Oct 13, 2009 at 11:33:15 AM | Attaching beams to model by face roofs - limitations?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Without testing, how about creating and aligning a reference plane to the u/s roof and then either align the beam to the reference plane or use the reference plane as the current 'work plane' for the beam as you draw the beam ?
Tue, Oct 13, 2009 at 1:46:25 PM | Attaching beams to model by face roofs - limitations?
robrevit2009
Hi Daryl. Thanks for your reply.
Yes, thats a very good idea as you can align and contrain the reference plane to the roof and align and contrain the beam to the reference plane.
Unfortunetly the type of roof I have, a stadium one, is curved in two directions.
I actually don't think its possible and I'm going to have to use something like Autocad Structural Detailing, but I wanted to sound you guys out first.
Installing analytical line into a in-place framing family?
Wed, Oct 14, 2009 at 1:44:41 PM
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:44 PM
Face-Based Family for Void Form?
Wed, May 18, 2011 at 10:19:38 AM
Same Opening Across Many Beams
Thu, Oct 29, 2009 at 7:10:29 AM
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:44 PM
Page generation time: 1.0483
