Forums >> Revit Structure >> Technical Support >> Buttons
17 Posts No Rating |
Hi, After installing 2010 i cant find all the buttons on the new ribbon, can i add buttons? and if so how? The first one im missig that help says should be in view tab is rendering but i cant find it, any help please? Adam
The render button can be accessed a few ways. You need to 'buddy up' with the 'Where is my command' dialog box under the help menu to locate all 2009 tools. You should also get used to using the F1 tool. You can then add it to your quick access toolbar or put it in your keyboardshortcuts.txt file.
This is what i used to get it working... If the Rendering dialog does not open automatically, use any of the following methods: - Type rr.
- On the View Control Bar, click
(Show Rendering Dialog).
but i cannot find that button on the view control bar, where should i be looking, the 'where is my command' doesnt help
You need to be in a 3D view to call up the rendering dialog box. Use the teapot icon on the visibility toolbar and 'rr' still works as well.
great, i know where to look now, thanks
If you are just getting your feet wet with RAC 2010 you may want to invest in this video series: http://www.myvbooks.com/cadclipsstore/stores/1/Get_Your_Feet_Wet_with_Revit_A_P175C24.jsp
buttons disappear |
Tue, Dec 17, 2013 at 9:01:54 AM
Buttons on taps not coming up for needed commands |
Tue, Mar 4, 2014 at 2:43:57 PM
project browser "expander" buttons disappear |
Thu, Jul 26, 2007 at 11:15:32 AM
Interface additional buttons? |
Sun, Dec 30, 2007 at 3:52:37 PM
Additional interface buttons? |
Wed, Jun 20, 2007 at 9:08:55 AM
Members: | 2115407 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
