68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Scale
see my image- the scale is set to 12" = 1'... the wall is one foot long that's for sure- but where is the 12 inches as the equal? an imaginary 12 inches? 12 inches where?
Imaginary. Hmm. . . explaining scale factor. Tough one to do in a discussion group. A scale of 12" = 1'-0" is the same as 12" = 12" which is basically 1 : 1 full size. Scale factor is 'view specific'. We use scale factors to 'shrink' things down (or scale them up) to fit on the sheet (which we print at 1:1). A sheet of paper is usually in the area of 36"x24" so in order to fit a floor plan (50'x35') onto the sheet we apply a 'scale factor of say 1/4"=1'-0" (1:4 or 1/8"=1'-0" (1:96) to the view. A scale factor of 12"=1'-0" is 1:1 and used to draw really small objects that fit on a sheet at 1:1 like a bread box or toaster oven. Also equally as important, scale factor sizes all annotation objects (text, arrow heads, tags) in that view so when they get placed on a sheet they are readable and consistant across all sheets. Wiki on Model Scale Factors > http://en.wikipedia.org/wiki/List_of_scale_model_sizes
thanks daryl- yes 12" = 1' is actual size.. so i'm trying to get it to print actual size.. please see my image and tell me if you know how to print that piece of 4" x 6" wall it's actual size..
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
scale image |
Fri, May 13, 2016 at 1:11:44 PM
Scale Bar Link To Titlesheet Scale. |
Thu, May 23, 2013 at 6:36:16 PM
scale check |
Tue, Oct 23, 2012 at 5:05:08 AM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
Members: | 2017373 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
