75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door Families using complex formulas
Mon, Oct 12, 2009 at 9:36:31 PM | Door Families using complex formulas
bsmith1982
Hi,
Hi,
I am setting up door families and i have set up tick boxes called DP1, DP2, DP3, DP4, DP5 (DP stands for door protection) and i have another field called Type Protection and basically I want this field to reference back to the yes no DP1 to DP5 tick boxes.
So    if DP1 is ticked the Type Protection field should say DP1
      if DP2 is ticked the Type Protection field should say DP2
      if DP3 is ticked the Type Protection field should say DP3
      if DP4 is ticked the Type Protection field should say DP4
      if DP5 is ticked the Type Protection field should say DP5
      and if none are ticked it should say NO
Furthermore I want another field called Door Protection Height and i want to reference it back to the yes no DP1 to DP5 tick boxes.
      if DP1 is ticked the Door Protection Height should = 150mm
      if DP2 is ticked the Door Protection Height should = 300mm
      if DP3 is ticked the Door Protection Height should = 300mm
      if DP4 is ticked the Door Protection Height should = 400mm
      if DP5 is ticked the Door Protection Height should = 900mm
if any one could help i would appricate it.
Tue, Oct 13, 2009 at 6:25:43 PM | Door Families using complex formulas
bsmith1982
Here is the answer I got that works from KarelCAD
"Brendan
Here is a solution for you:
For the Type Protection Field   =if(DP1, "DP1", if(DP2, "DP2", if(DP3,
"DP3", if(DP4, "DP4", if(DP5, "DP5", "NO"Winking))))
For the Door Protection Height Field =if(DP1, 150 mm, if(DP2, 300 mm, if(DP3, 300 mm, if(DP4, 400 mm, if(DP5, 900 mm, 0 mm)))))
Glenn Barrett
Application Specialist
KarelCAD"
Complex Family Editing
Mon, Mar 9, 2015 at 1:01:45 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Door Family Formulas
Fri, Dec 12, 2008 at 3:00:47 PM
Families - Locking complex geometry
Thu, Dec 4, 2014 at 10:48:22 AM
"can't find solutions for formulas" error
Wed, Aug 3, 2016 at 5:46:21 PM
Page generation time: 0.5853
