67 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Creating new project from existing
7 Posts No Rating |
I need to create a totally new project from and existing one.
Is there a simple way to transfer ALL data and give it a new project name?
Post edited on 2005-08-22 11:29:44
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Provided the project is not a central project, simply open the current project and do a "save as" or copy using Windows to new location and rename.
If the project is a central project, then it depends on what version you are using. If worksetted and central in 8.0 or less, open the central file on the server and do a save as being sure to make a new cental file location for a different project.. If using 8.1 you can experiment with the new detach from central command which I have not played with yet.
If anyone else knows better/easier ways chime in.
HTH
Tom
7 Posts No Rating |
Thanks.
Yes it is a central file in 8.0. That's why I was having problems.
We have just received 8.1 and have not installed it yet. Will have to try the new command.
Creating Existing Footings in Revit Structure |
Mon, Jan 4, 2010 at 12:09:19 PM
CREATING LEVEL IN NEW PROJECT. |
Mon, Jan 6, 2014 at 10:00:33 AM
Creating existing plan |
Fri, May 21, 2004 at 9:36:50 AM
Stupid ? # 234 - project browser |
Fri, Nov 20, 2009 at 1:23:50 PM
Existing Elevations not Referencing Existing Plans |
Thu, Dec 5, 2013 at 3:57:29 PM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
