Forums >> Revit Building >> Technical Support >> Does anyone know if there is something similar to xrefing in Revit?
2 Posts No Rating |
Hello everyone, does anyone know if there is something similar to xrefing in Revit? I am working on a 16 story condo project and levels 6 thru 14 are exactly the same. Anytime I make a change to level 6 I have to copy up again levels 7 thru 14. Is there a way to link levels 6 thru 14 so that I only have to make a change at level 6 and all the other level would automatically change just like using xrefs in AutoCAD. Any help would greatly be appreciated. Thanks, vp Victor Pacheco Jr.Architectural Project ManagerTampa, Florida USAvictor.pacheco.jr@gmail.com
Someone may know a better way than this, but I would try creating and copying a group.
2 Posts No Rating |
TKennedy, thank you for the suggestion I will try it out. Thanks, vp
----------------------------------- Victor Pacheco Jr.Architectural Project ManagerTampa, Florida USAvictor.pacheco.jr@gmail.com |
Read your HELP on LINKS. I hate to use the term x-ref because Revit's file linking is very different. You can link in CAD, DWF's or REVIT projects.
9 Posts No Rating |
If they are exactly the same, does each floor need its own fully modelled level? Why not model one floor fully, then use that as the typical floor plan. Then you can leave all of the duplicate geometry of other floors out, saving you resources and time.
Edited on: Thu, Oct 8, 2009 at 1:17:14 PM
as wwwhub said, you can use linking system. Just use the import/link button on file column, and all your parts of proyects will update as u work on them. Try to use a different file for every part, like a file for topography, one for other buildings, roads, building A, building B ( in case you need to work on different parts of the proyect) AND A FILE that have it all HOSTED. The real use of what are you asking is when you work on a team, and split the work make all easier.
Linked files is exactly what you need, make that floor a model of it own and just link it in.
J. Allen Ball Revit Architecture 2010 Certified Professional |
create similar greyed out |
Wed, Apr 26, 2017 at 3:17:40 PM
Similar Tags - Interior Elevation |
Fri, Oct 24, 2008 at 10:32:16 AM
Similar Callouts |
Fri, May 12, 2006 at 4:25:50 PM
Sat, Dec 23, 2006 at 10:12:14 AM
Workset |
Wed, Apr 27, 2005 at 11:12:07 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
