68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> REvit MEP
Wed, Oct 7, 2009 at 4:58:44 PM | REvit MEP
4ABs
Hi,
DId somebody know why I can not change my electrical panel setting in the DISTRIBUTION SYSTEMS...( THERE ARE THREE IN THE ELECTRICAL SETTING BUT SHOWS ONLY 120/208 Wye IN THE SCROLL DOWN MENU.
REGARDS,
ALBERTO
Thu, Oct 8, 2009 at 11:02:02 AM | REvit MEP
JillBernhardt
5 Stars: 3 Votes
The distribution system that a Revit electrical panel can be assigned to is determined by the settings defined in the family of the panels you choose.  Notice that out-of-the box panel families have names such as Lighting and Panelboard - 208V to give us the heads-up that it can only connect to 120-208V objects - a 120/208 distribution system, not a 480/277 system.  The software is designed to prevent us from making the mistake of connecting mismatching objects of differing electrical requirements to the same circuits or panels.
Jill Bernhardt
    Blog:  The BIM Bulletin
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
From 2D CAD MEP files to Revit MEP
Tue, Feb 9, 2010 at 11:12:10 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Page generation time: 2.4204
