80 Users Online (79 Members):
Forums >> Revit Structure >> Technical Support >> Adding roof bar joists on different hight brg. ends..
4 Posts No Rating |
I am a revit structure newbie (long time autocad user)... We are doing a project that has bar joists brg. on cmu ICF and CMU walls.. the joists are higher on one end and slope to the other end... I can get the joists to slope if I do them one at a time, but if I try to do a system of them they are level with the floor.. I will say I am very frustrated in learning revit, I am the head cad guy at our firm and I have read mastering revit structure and am just struggling in general.. People I talk to either love it or hate it.. any idea of being able to do these as a system..
Hi and Welcome to Revit World... I'm not a "Structural guy" but here you have some sites from struct.: http://bimandbeam.typepad.com/bim_beam/ and: http://www.revit-waterman.blogspot.com/ Keep learnig and you gonna enjoy Revit....
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Hi fleming welcome here....."I will say I am very frustrated in learning revit".....don't give up, just carry on!!!!....practice makes perfect......
“Learning never exhausts the mind.” — Leonardo Da Vinci
![markitekdesign Avatar](user_avatar/110469.jpg)
![4.5 Stars: 71 Votes](/images/stars_4.5.gif) |
Just be patient,more practice...may be next time you can do it...right...
15 Posts No Rating |
you can put a reference plane and use it to create your beam system. another way that I've done it (don't know if its a good way or not) is un-pin the joist and give the correct elevation in the properties window (start & end elevation). hope this helps
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
First thought- create a reference plane defining the geometry (slope) you want the top of your bar joists to adhere to. Just re-name your reference plane (in the element properties box) after you've drawn it. After you've renamed it- simply select the reference plane from the design bar when placing new beams and joists. It will draw the joists along that reference plane. In terms of making chages- make changes to the reference plane, not the individual joists. You can also use framing systems to slope framing. If you go to a section and select the system (NOT the individual framing members) you'll see a 'reference plane' show up. You can rotate this reference plane by disjoining it (an option on the design bar) but I would not call this a preferred method. Does that make sense?
Sloping Bar Joists? |
Thu, May 7, 2009 at 9:41:08 AM
Sloping joists to the roof deck |
Mon, Apr 4, 2016 at 11:21:15 AM
Manipulating Bar Joists |
Fri, Feb 16, 2007 at 12:32:07 PM
wall display properites |
Thu, Sep 18, 2008 at 11:06:37 AM
AAARRRGGGHH! Joist questions! |
Thu, Nov 17, 2011 at 11:35:04 AM
Members: | 2017021 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
